configure mld snooping fast-learning
configure mld snooping fast-learning [on | off] [vlan vlan_name]
Description
Configures fast-learning mode.
Syntax Description
vlan_name Specifies a vlan name
Default
off.
Usage Guidelines
When MLD snooping is enabled on a VLAN, learning of group entries will happen only when the next periodic query is sent by the querier in the network. When fast-learning is turned on using this command, a query is sent under the following conditions:
  • When MLD snooping is enabled.
  • When MLD snooping VLAN is operationally up.
  • Group join limit changed through configuration.
Query generated for faster learning uses unspecified address as the source address (both L2 and L3), unless the switch generating the triggered query is the querier for the network.
configure mld snooping fast-learning on
This command was first available in ExtremeXOS 15.2.
Platform Availability
This command is available on platforms that support the appropriate license. For complete information about software licensing, including how to obtain and upgrade your license and which licenses support the MLD snooping feature, see the Switch Engine v33.1.1 Licensing Guide document.
